mkzwoo
FREE CHAOTIC MONOSYNTH
Bored of the same old synth sounds? Newfangled Audio's Pendulate is refreshingly different. Pendulate is a chaotic monosynth that uses a brand new double-pendulum-oscillator to create previously unheard sounds - biting basses, searing leads, and gritty textures. It can smoothly fade from a sine wave to total chaos, with an expanse of territory to explore in between.CREATE THE CHAOS
Pendulate’s chaotic oscillator is based on the physics of a double pendulum. What initially looks like randomness contains underlying patterns, interconnectedness, constant feedback loops, repetition, self-similarity, fractals, and self-organization. When designing the Pendulate oscillator we took great care to bring out these underlying patterns to create something both chaotic and musical.FEATURES
- Novel chaotic oscillator based on the double pendulum makes sounds you’ve never heard before, but will want to hear again
- Wavefolder based on the one in the Buchla 259 Complex Waveform Generator, adding MIX and CUTOFF
- Low Pass Gate based on the Buchla 292 adds controls for POLES and RESONANCE
- Innovative modulation UI allows modulation over every control from the main page, allowing up to 325 simultaneous modulation routings
- MPE support allows amazing control from innovative new controllers
- Looping Envelope and LFO each have multiple outputs generated at once, and can modulate each other, like a modular synth
- Modulation! Every mod output to every control means up to 325 modulation points in an intuitive single pane
- Animations! The Double Pendulum, Wavefolder, and Low Pass Gate modules each have animations to show how each module responds to your input, and to modulation
- Fully resizable UI!
- Intuitive Midi Learn functionality allows you to assign MIDI CCs to any control with just a click
- Three unique color schemes to customize your look
- 136 Presets including artist presets from Matt Lange and Matthew Wang
Pendulate - Free Cinematic Synth Plugin | Newfangled Audio
Get your free copy of Pendulate, a unique synth plugin that's great for cinematic sounds and characterful basses, with custom modulation options. Download as VST, AU, and AAX.
www.newfangledaudio.com
